Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Can I replace my iPhone 6's front cam module with iPhone 6 plus's one?
Hi!
I have a working iPhone 6 with dodgy proximity sensor. I happen to also have a broken (water damaged) iPhone 6 plus. I looked online and see that both have similar looking front cam module. Is it possible to just put the front cam module from iPhone 6 plus to iPhone 6?
Thank you!
Add a comment
Chosen Solution
In short, no. They are actually different sizes even though there are several similarities.
Score 2
Add a comment
If I'm not mistaking, the main problem is that the 6 plus having the bigger screen, the sensor is longer. So it wouldn't fit in a iPhone 6 since the screen is smaller, the sensor is shorter as well.
2 Comments:
I have it side by side and it appears to have the same dimensions, at least from the outside
by
Are you sure you are looking at a 6 and 6 plus? When comparing the parts online, they look similar but there are size differences between the two.
by
Add a comment
Add your answer
Evan Aristya Yudha will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 63
