Cartridges are full but still doesn't print
Hi, I got a Canon MG 2520. The printer is perfectly installed and everything. However when I try to print a document (including the alignment page), it comes out as just a blur and doesn't print properly. The printer doesn't indicate the cartridges are empty either. And when I check they appear to be full. I performed all the cleaning procedures suggested as well but still doesn't work. Scanner however works perfectly.
Does anyone know how to fix it or any suggestions?
Thank you.
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
1 Answer
Chosen Solution
The encoder strip gets dirty. Cleaning it usually resolves this issue. Heres how to check it. If you open up the front where the paper prints, theres a clear strip that goes from left to right (its right above the greasy metal strip). If the strip is dirty (typically with ink smudges), clean with a little bit of water and q-tips. BE GENTLE! And, be sure to UNPLUG the machine before proceeding. After cleaning do a test print to confirm.
Score 1
Add a comment
Add your answer
Lakshitha Perera will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 34
