Guides and support for various television (TV) brands and styles.
Why is LCD TV backlight flashing?
Samsung LN-T4065F LCD TV 40"
The TV is 10 years old and has 5700 viewing hours.
The backlight is flashing on and off at a rate of about 3 times/sec. You can see a video of it here: https://www.dropbox.com/s/q7ngflkituz774...
This used to happen periodically then go away overnight. Now it's not going away.
How can I debug if this is an inverter problem? I have a multi-meter. Or should I just buy the $17 inverter and hope for the best?
Add a comment
1 Answer
Chosen Solution
The backlight inverter is damaged. Needs to be replaced. Requires soldering. You could send the board off to a board repair shop in your area or mail in
Score 2
12 Comments:
What kind of soldering? Videos I've seen show that replacing the whole board is basically plugs/wires. https://www.youtube.com/watch?v=Kwhih4U1...
by
You could do that. Would be much easier
by
Did some multi-meter tests on the inverter. Couldn't find any problem. I'm just going to spend the $17 for the new inverter board and see if it fixes it.
by
Ok. Let us know if you need anything!
by
New inverter fixed it!
by
Show 7 more comments
Add a comment
Add your answer
Matt will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 4,109
