Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Questions View all
No power, no charge , no battery indicator. Dim green LED on Magsafe
My Macbook pro mid 2012 is dead
It does not turn on either on charger or battery or both.
No fans, no screen flashes, no noise at all. Completely dead.
I tried two charger, two battery. Nothing. Battery-unplugging and magsafe unplugging did not work for me.
When plugged in, I can see the dim green light on the magsafe connector. If I flip the connector and look from an acute angle, I can see dim orange.
I looked up the SMC reset... but duh, the computer won't turn on at all so these keystrokes do nothing to bring it to life.
I did try another DC-in board. It did not help.
I found this thread which is quite similar issue. (No power, no charge, no battery indicator. Dim green LED on Magsafe). The guy "zzz" suggested a video tutorial https://www.youtube.com/watch?v=sI7rvFLU.... But I can figure out where to solder to wire.
Please help if you have any idea or suggestion.
Thanks,
Add a comment
1 Answer
A trick similar to the SMC reset that sometimes works as a last resort is unplugging MagSafe, unplugging battery, holding down power button for 15 or so seconds, plugging in battery, and then MagSafe. Did anything in particular happen to the MacBook before this?
4 Comments:
I tried this but did not work
by
Is there anything that happened to the computer beforehand? Such as drops or spills?
by
Drop: Yes
Spill: No
by
Have you tried another charger? I'm not a soldering expert so I can't really help with anything board level unfortunately.
by
Add a comment
Add your answer
Brian will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 8
All Time: 1,560
