Help the new LCD -digitizer wont stay trying to put back together
I purchased the new LCD/DIGITIZER for my ipod touch and it wont stay together when i try to push the screen in, anyone??
jkrause,
What type of adhesive did you use? I use this one and trim to fit the 4th gen. as they haven't come out with a 4th gen adhesive yet:
https://www.wholesalegadgetparts.com/pro...
Make sure you get all of the old adhesive off and clean the surfaces with isopropyl alcohol then trim and stick the double sided adhesive to the surfaces where it previously was. Use a spudger or similar tool to press the top layer of paper firmly into place then remove the top paper and carefully stick the digi back on working from the top to the bottom making sure the ribbon cables stay attached! Then put it face down on a folded paper towel or cloth on a flat hard surface and press down firmly but gently for a minute. That should get it stuck and good! Please let us know how you do!
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,972
