Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
iPhone 6 won’t turn on
I ordered a new proximity sensor as it somehow disabled siri and would black out my phone screen now and then, after the replacement we accidentally broke the home button ribbon.
It is now not turning on and not detected by any pc ? Could this just be the home button?
3 Comments
or is the phone fully broken
by
Thanks it is 100% installed properly so what could be disabling the phone to turn on during the replacement of just the promimity sensor?
by
I don`t think so the home button flex makes such type of problem,I solved to many problem like that just change the U2 ic,Your problem solved.
by
Add a comment
1 Answer
Chosen Solution
Siri uses the microphone included in the proximity sensor flex. It appears that your replacement flex is either defective or improperly installed. You may want to double check your steps by following this guide. The Home Button should not cause the phone to go black .
Score 1
3 Comments:
by
If it is defective, it could be shorting out the power IC's.
by
Can this power IC be fixed?
by
Add a comment
Add your answer
Jack will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 100
