Apple extended hardware test error codes 4NSN /1/40000000:TH00-9.00
what is mean Apple extended hardware test error codes 4NSN /1/40000000:TH00-9.00
Update (08/24/2017)
iMac 27" 2.66 GHz intel Core i5
Memory 8 GB 1067 MHz DDR3
Mac OS-X 10.6.8
I changed the hard drive with this: WDC WD1005FBYZ-01YCBB1
- Capacity: 1 TB (1,000,204,886,016 bytes)
- Model: WDC WD1005FBYZ-01YCBB1
- Revision: RR04
- Native Command Queuing: Yes
- Queue Depth: 32
- Removable Media: No
- Detachable Drive: No
- BSD Name: disk0
- Rotational Rate: 7200
- Medium Type: Rotational
- Partition Map Type: GPT (GUID Partition Table)
- S.M.A.R.T. status: Verified
- Capacity: 209.7 MB (209,715,200 bytes)
- Writable: Yes
- Writable: Yes
- File System: Journaled HFS+
- BSD Name: disk0s2
- Mount Point: /
more about the new disk :
HDD WESTERN DIGITAL WD1005FBYZ GOLD DATACENTER HARD DRIVE Χωρητικότητα: 1 TB.
- Interface: SATA III 6 Gb/s.
- Form Factor: 3.5"
- Windows, Windows Server, Linux και Mac OS.
- RoHS Compliant: Yes
- Rate (max) Buffer to Host: 6 Gb/s.
- Host to/from drive: 200 MB / s.
- Cache: 128 MB.
- Rotational speed 7200 rpm.
Please can you help me to understand and fix this problem
Thank you!!!
6 Comments
What is your system model number? As it has a bearing here on what the correct answer.
Look at the bottom of your systems foot to find the serial number or if you can still access the desktop go into About This Mac and grab the serial number there. Plug it into here: EveryMac - Lookup. Then paste your systems URL here for us to see what you have.
by Dan
Let's try again... giving us the internal systems specs is not very helpful! We really need the model as you're just given me the internal specs not the system it self.
Think of it this way your listing off the different organs of your body here: lungs, heart, liver. But is that you or just your guts? I need to know you as you not your internals.
Go to the blue link above and plug in your serial number and then paste the system info EveryMac offers here (the URL will do)
by Dan
URL is Serial Number system?
by elen
Your WD Gold HD specs: WD Gold Datacenter HD's
I'm not sure I follow your reasoning on getting this HD as the lower cost WD Blue or the high performance WD Black series should be more than fine here. The Gold series is intended for high I/O within a data center. That's not to say it wouldn't work here it's just overkill on what this system will likely encounter in even the heaviest usage a single person could do.
Until we know what your exact model is this may not be the correct drive.
by Dan
If we guessed correctly this is your systems specs: iMac 27" 2.66 GHz i5 (Late 2009)
by Dan
Show 1 more comment
