Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2397 Questions View all
Question Closed
Help! No one can hear me when I answer a call on my ip4!
Whenever I answer a call I can hear the caller clearly - all they get is complete silence or crackerling even when I am speaking. I have tested the mic by doing a voice recording and that worked great, so the mic is fine - it played back perfectly. If I press the phone the back of the phone just above the apple logo it sometimes works and the person can hear me - any ideas would be really appreciated.
Add a comment
Has it been dropped? All of the connectors are right where you mention, above the apple logo. I would follow the step-by-step guide found here to check the connections, otherwise, just take it back to the apple store. Its still under warranty and they will do it (or replace it with a new phone).
Add a comment
I had the same problem with the 3G phone and it was a bug with the iPod app. This worked for me and hopefully will work for you, too:
http://bluescreensolutions.blogspot.com/...
Add a comment
If you're comfortable opening your phone, try replacing the Power Proximity Light Sensor Signal Flex Ribbon Cable. The mic is attach to that.
Add a comment
I had the same problem with my tracphone and it was only a microphone glitch
Add a comment
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 13,984
