Touchscreen no longer working
Hi. I have just fitted a new display assembly on my iPhone 6 plus following the guide on here but when i turned it back on it shows the lock screen but wont let me swipe or type in pass code anybody got any ideas or could it be a faulty display assembly?
4 Comments
Was the damaged screen working? Did it have touch? If it was, reconnect it to make sure it still works to eliminate the new screen as not working. Also, did you make sure to put the same screws back in the shield in their same spots? It could be several things...Bad LCD, connectors not lined up when putting them on, Long screw damage, or just a case of touch disease
by The Microsoldering Shop
im very careful with the layout of the screws so all screws are from where they were located before and yeah the damaged one was working
by Darren McIntosh
try the damaged one again if you still have it...if it works and you are sure that the new one is connected correctly...then I'm pretty sure its just a defective screen
i took the new screen off and there was a tiny piece of plastic in the connector preventing it to seat 100% Thanks anyway
by Darren McIntosh
