This is a standard irrigation system control box used for residential homes. It can manage a maximum of six valves.
8 Questions View all
Not getting any power to the unit.
After returning from a trip, I discovered I had a blank screen and there is no power to the unit.
Score 1
1 Comment:
My Rain Bird ESP- 6TM's screen says "PR OFF", while there is power in my wall outlet. Not any button on the controller now works. I checked the fuse, the fuse is good. I removed the lithium battery, the "PR OFF" went away, I put the battery back in, the "PR OFF" came back. Can anybody tell me what else to check and how to fix the problem? Thanks.
by
Add a comment
REF: http://www.rainbird.com/documents/turf/m...
Have you checked the breaker? The wall outlet?
If power is at the wall outlet, then you can use a multi-meter to check power at the end of the power supply cord at the (24VAC) terminals inside the control panel - see Page 34. This link gives you the part numbers in case you need to replace: http://www.rainbird.com/documents/parts/...
Also, check out the troubleshooting guide on page 36.
Add a comment
My unit has a reset button the back of the door. I now have readings again!
Add a comment
Add your answer
Larry will be eternally grateful.
Past 24 Hours: 8
Past 7 Days: 87
Past 30 Days: 322
All Time: 15,455
