Model A1418 / Late 2013 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
254 Questions View all
LCD Display doesn't work
Hi, guys!
I've problem with my iMac. LCD Display shows black screen (no picture at all), external display works correctly through Mini Display Port - HDMI. 4th LED doesn't lit up, only 3 LEDs are lit up.
I've already changed LVDS cable and LCD Display - problem still exists. But if problem is a logic board or graphics - how external display works?
Add a comment
Chosen Solution
I got the answer for my problem: Blown fuse on the logic board.
1 Comment:
What fuse? F4400 or L4400?
by
Add a comment
Most Helpful Answer
See if a flashlight at a sharp angle resting on the display allows you to see the faint image of your desktop icons if it does then your backlight circuitry is the issue.
Update (08/17/2017)
In that case you either have a damaged connector on the display or the logic board or the cable is defective. Otherwise the display it's self is bad.
Take some detailed images of the connectors on both the display, logic board and cable ends so we can see the pins and the latches. Maybe we can spy what's up here
Score 2
1 Comment:
Checked it out. No image at all...
by
Add a comment
Add your answer
Eccofreerider will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 763
