Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
How to put iPhone together?
I opened my backcover, and exidently cut over some wires. I put them together again, but appearently it was wrong, because I can only here sound through the soundspeaker. When I opened up my iphone i noticed that there were numbers to each wire, and I was wondering if anyone has a picture of the numbers so I can put it together right :)
Score -1
Add a comment
1 Answer
Chosen Solution
no1 is from the LCD and plugs in top right of logic board just below the camera (it lies horizontally)
no2 is from the digitiser and sits to the left of no1 and a little lower ( it lies vertically)
both these connections snap on to the corresponding connector
no3 from earpiece/proximity sensor slides in- tab slides from the top of the logic board, into/under the white connector and then you close the black (or in some cases white) lid over. this tab doesn't need to be pushed in all the way to the white line, once it feels snug stop pushing. this connector is immediately above connector 2.
the correct order for replacing the connectors so the lid closes is 3, 2, 1. the connectors all end up with the cable needed directly over them as you prepare to close up... so there shouldn't be too much confusion. chose any guide for this phone and you should see the numbered cables on there! iPhone 3G Front Panel Replacement
Score 2
Add a comment
Add your answer
Johnny will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,956
