Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose gold, gold, silver, black, and jet black.
2264 Questions View all
When home button is clicked Once it does 6-7 rapid clicks
Hello I have a customer with an iPhone 7. I replaced the screen and the home button is odd. I click it once and the home button gives me about 6-7 rapid clicks. Is it the home button pressure sensor? How can I fix this.
Score 1
Add a comment
1 Answer
Hey!
Try to disconnect the Home-Botton connector from the flex cable behind the LCD assembly, remove the Button completely and resest all parts again. Then test it again.
2 Comments:
Tried that still having same issue.
by
Okay, in this case - if you are really sure all is sitting in place and is connected correctly - it could be possible the flex cable or button itself was killed. I rememvered the button and its board sticks very hard at the back of the LCD assembly and needs to remove carefully. Maybe you detect any damages at the board or cable?
And I think you should try another home button-flex.
by
Add a comment
Add your answer
Hunter Kegher will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 3
All Time: 677
