Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
Problem with battery?
I just used the battery replacement kit I bought from this website and I'm not sure if I did something wrong. I made sure the battery was connected really well and screwed it tightly. I followed the directions to drain my new battery to below 10% and then charge it to 100% uninterrupted but it took almost 4 hours to charge up to 100% is there a reason why it took that long or did I do something wrong ?
Add a comment
1 Answer
Chosen Solution
There are a number of possible reasons why the battery took so long to charge:
- Bad charging cable (damaged / worn out)
- Damaged charging port
- Using the 1.0A wall charger instead of the 2-2.4A wall charger (You can charge at 1.6A speed instead of 1A which is noticeably faster)
Note that using a higher amperage charger will not damage your phone.
Score 2
1 Comment:
Same thing I was going to say. The charge port is not providing enough current to charge the phone at optimal speed
by
Add a comment
Add your answer
melia guillen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 138
