2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
774 Questions View all
No Keyboard, No Touchpad, No Batterie MacBook vs white wine
Hey Guys,
I got a Macbook Pro Retina 15" mid 2015, which got contact to white wine. It is of March 17" and the accident appears three weeks after bought.
Yesterday I cleaned the whole Logic Board with alcohol and after that the Book works.
The Logic Board is in good condition and the water indicators on the Logic Board are white.
All of the others (on the batterie) are red.
The Book plays sound and works fine, but the Keyboard and the Touchpad won't work. I saw that the cable of the Touchpad is in bad condition and i think it is a cable for touchpad and Keyboard, right? But the Keyboard has another cable, too.
The backlight of the keyboard works fine!
Another problem is the batterie.. The charge is still on 81% and won't get higher. When I plugged the Powercable off, the MBP is off.
So is the batterie or the system in the batterie the failure or magsafe?
Thank you!!
By the Way: Is it possible to change the indicators?
Sorry for my bad english
1 Comment:
Didn't work. But mit internal Keyboard isn't working also.
I tested it with a external Keyboard (USB).
by
Add a comment
1 Answer
Hi
please try this steps.
Connect the power adapter to the Mac. On the MacBook / Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time. Release all keys and the power button at the same time – the little light on the MagSafe adapter may change colors briefly to indicate the SMC has reset.
if it still has the same issue should book an appointment with Genius BAR.
Regards
Dushyant
1 Comment:
Hi,
i would try these steps.
When it shouldn't work, i have to replace the battery right?
I won't a appointment at genius Bar, 'cause I want to repair it by myself.
Thank you.
by
Add a comment
Add your answer
Nick Meyer will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 96
