The Mac Pro First Generation is an Intel Xeon-based workstation computer manufactured by Apple Inc. The first generation model includes the machines from 2006 through 2008.
317 Questions View all
Where are the Power On Pads?
Hi,
I have Mac Pro mid 2010, 5,1 Quad core.
It was working fine since 2010. Few days back it stopped working and a red light near the CPU heatsink appears. I found on forums, that it might be due to dust, so I cleaned with a blower after removing all the parts one by one. After fixing everything back again, it worked fine without any red light.
Next morning when I started it again, it's dead. No light, No sound, no fan movement, nothing is running.
I have noticed after reading Apple repair guide I found online Mac Pro (Mid '10) - Apple Technician Guide:
  • When connecting the Mac Pro to AC power, the LEDs for OVTMP CPUA and OVTMP CPUB briefly flashes red and also momentarily flash red immediately after the Mac Pro is disconnected from AC power (note 1 & note 2, page no. 34)
  • After pressing DIAG LED button onboard, the 5V STBY LED illuminates. This indicates the Power supply and Logic board is fine.
Main Issue
The power button was giving me a problem from last 1-2 months, I need to press sometime 2-3 time to start the system.
I have read in the pdf that jump the SYS_PWR solder pads to turn ON the Mac Pro. But I am not sure which are the correct Power-On pads are as there is no exact solder around SYS PWR points.
Can someone please suggest what is the best solution or which are the correct Power-on Pads?
Thanks
1 Comment
Hi, I have the same problem with my Mac Pro Mid 2012. Were you able to find a solution to this error?
by
Add a comment
1 Answer
Most Helpful Answer
I recognize this is as an old question but answered for completion sake. Here is the image showing the power on pads located on the backplane board
Score 3
Add a comment
Add your answer
jenny mc will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 753
