Samsung's flagship phone, the Galaxy S8. Released in April 2017.
304 Questions View all
phone will not come on, shows triangle and will not charge x2
Sooo I have and S8 and S8+ doing screen repair on both. Now the phones will not come on, they only show triangle's and will not charge. I know this was an issue with the thermostat on S4's many years ago and had to change the charge port. I am not sure what needs to be done to fix this issue. I have a new cable and charge port on order but was not for sure if any one else has had this issue.
Score 3
Add a comment
Most Helpful Answer
Did you completely reassemble the phone before trying to charge and power it on? With previous Galaxy S series phone generations I can and often do test the phones before reassembling the midframe. But I found that with the S8 and probably likewise with the S8+ that you need to fully assemble the phone first. On one of my first S8 repairs I found that without the midframe on I got an error that looked to be like the battery thermostat triangle error experienced in previous models. But when I put the midframe on, the problem was resolved. Apparently, some contacts must be made to complete a circuit. Hopefully, that is all that you are experiencing in your situation.
Score 3
2 Comments:
Thank you that was it!
by
Thank you. I solve my problem! If you do not make contact, my terminal did not turn on or charge. After putting the screws and the midframe, it reloaded and started correctly.
by
Add a comment
I had the same issues. I realize it was because of the plastic covering when you open the back panel.
open the back up you’ll see the plastic covering. (which is outline in the red)
once you flip it to the side you’ll see these connectors like below. (yellow outlines)
If these aren’t making contact, you’ll get the overheating on the screen, and cant charge your phone.
Score 1
1 Comment:
by
Add a comment
I had the same issue with S9, so what worked for me was to use a wireless charger. After a few weeks I was able to go back to using a cord charger. My dadughter started having the same issue with her S9. She had to use the wireless charger too. I was playing around on her phone and cleared the yellow triangle with the ! by turning the phone off then plugging in the charger into the port and holding my finger down on the middle button lll ㅁ < you will see the percentage loading and the triangle disappear. i also made sure look at device care in settings and see if there is anything in red. Hope it helps
Add a comment
I had android with ! in a triangle.
*Turn off cell
*Plug in power cord to wall (regular plug in)
*Do the next two things together
1-hold down power button while….
2-plug in charger to cell
*Keep holding power button down. It will throw a fit…..beep…vibrate…screen shows something…
As soon as you recognize that it is repeating what ever it does (about 3 times) release power button.
It will boot up and come on.
Charge it up
Add a comment
Add your answer
The Screen Spot will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 30
All Time: 8,194
