Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2692 Questions View all
Why is my phone messing up.
I got my phone fix by a professional(works at apple) and after I got it back New screen an everything it seemed fine. After a couple hours with it, i would be scrolling down an it will mess up it start scrolling up as I'm going down or even zoom in and out. Like it loses calibration. I ask the guy that replaced it but he won't look at it unless I pay him. If I set it down and not even lay a hand on it ,it will start opening random apps or do things on its own. Can someone help me with this?
Update (08/09/2017)
It was replaced due to a crack
Add a comment
1 Answer
Chosen Solution
Why was your first screen replaced? Drop, crack, unresponsive, grey bar on top?
From what you described, it sounds like it could be a few things.
1. Touch disease: a defect in mainly the iphone 6 models mother board with a couple IC chips responsible for touch. You can look it up online to see if that is what you are experiencing.
2. Long screw damage. Each screw on the Iphone lcd flex shield "MUST" be put back in same hole it came from or it can cause damage to the motherboard that sits under these little screws and can cause trace damage.
3. you just got a defective screen and should try a different one to include or rule out the first 2 possibilities.
Score 2
1 Comment:
for the OP
Err..that "professional" who worked on it doesn't seem so professional if they won't even look at their own repair without charging a second time. I would consider a better repair shop/technician too.
by
Add a comment
Add your answer
Maria Rodriguez will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 1,243
