Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus. Identifiable by the model numbers A1549, A1586, and A1589.
4420 Questions View all
If my U2 IC Chip is broken, does charging the phone damage it more?
Does charging the phone while having a broken u2ic chip make the problem worse?
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
I am surprised that it would still power on with a "Broken" U2 IC. Is it physically broken or do you just think it may be? What are the symptoms you are having>
Score 3
Comments:
Battery draining after it charges, random battery drain with a new battery
by
to eliminate the charging circuit you should use a multi meter to measure for charging voltage at battery connector...but sounds like either bad battery, charging port or Tigress/or U2.
Here is a link for testing:
https://www.youtube.com/watch?v=Konvdpt4...
by
Add a comment
Add your answer
Eric Lieu will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 96
All Time: 2,969
