External Wifi Antenna iPad Mini 2?
We use a Pulsar thermal imager that sends a 2.4 gHz signal to my iPad mini. The signal is very weak with a 15m line of sight range.
We have two shooters strapped on the roof of a Jeep Wrangler with the thermal scanning for hogs and the iPad is mounted by the rear view mirror transmitting that signal to me and other customers inside. It drops signal like crazy and has annoyed me to the end.
It is imperative that we receive signal and the unit doesn't support a hardwired connection. Since there is no way to install an external antenna directly to the iPad, my question is this:
Can you get a jumper with a SMA connection and jump into the iPad wifi cable then mounting the connection to the iPad casing. (Doesn't have to be pretty it stays mounted in the jeep), then connecting a 2.4 gHz external antenna to that which has a long lead and can run to the roof? It seems feasible and quite simple. But has never been done that I've researched.
The thermal is expensive as !&&* and they have no support for my issue as my issue is a simple line of sight problem, so the issue will have to be addressed at the monitor end.
PLEASE HELP!
3 Comments
Pulsar Software
Boy! These IR imager systems are really low power! It sounds like this is intentional! Spooks like ultra low signal gear so they don't get seen (RF wise).
If they can't be seen though a fiberglass roof which is only about 4 feet of distance here thats very low!
by Dan
Correct me if I'm wrong, but with my little knowledge of wifi extenders. The extender is "paired" with a weak wifi network from a router. Usually a pairing process has to take place. Then the extender transmits that signal as a middle man basically just making that point the "point of the router." The thermal imager has no way to pair to a router? It has a button that turns the wifi on and off and then you find it on your iPad and connect to it. Or will simply turning the extender on gap the wifi that's already there via the two antennas?
by Clayton Reynolds
The extender unit (repeater) will be the AP (access Point) for both your IR units, the iPad will then be the AP for the repeater. The trick here is you need to start up the iPad first so the repeater can connect to it, then you turn on the IR units as they will see the repeaters AP (stronger signal). Review the manual it's fully explained.
Trust me this is a cake-walk!
by Dan
