Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
iPhone 4 backlight very dim!
My Iphone 4 backlight is very dark, I can see its screen with a flash light. How can i fix it? Thank you.
Score 1
Add a comment
Most Helpful Answer
Could be the iPHone 4 backlight IC is faulty you can purchase one here.
Score 3
Add a comment
You need a backlight IC.
Score 1
Add a comment
you can increase the brightness by going into settings > brightness
Add a comment
you do not need a backlight IC. i went to the Apple once with the same problem and they said take good care of it and it will eventually work. what you need to do is open the iphone and just the out the battery and then leave the iphone for a few days (2-3). then just place the battery back into the phone and see if it works.
Add a comment
you can get the backlight IC , coil and fuses here
Add a comment
You should check that the connection to the lcd is fully seated.
Add a comment
My iphone 4 dim backlight. Please help.
Add a comment
Add your answer
trang vu will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 25,152
