Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
My screen is dim and flickers after wifi antenna replacement.
I mistakenly plugged the battery in before I did the lcd connector and others. I know, very silly/dumb mistake. Would this have shorted the lcd connector? Everything seems to be working fine. At first my touch screen wouldnt work and it had a grid of grey lines but i unplugged and plugged that back in and it disappeared and the screen started responding to my touch again. The remaining symptom is that the phone starts up flickering and is very dim. Do you think this is because I shorted something by plugging the battery in too early? or is it possible that the connector is dirty? (I have cleaned it many times). Thanks for your thoughts, I appreciate your input!
Add a comment
1 Answer
Chosen Solution
Dim? or backlight is not functioning? Sounds like you may have shorted the backlight circuit and (Blew a fuse) need to replace backlight filter or even damaged the backlight circuit beyond that. I would recommend taking it to a Microsoldering repair shop for repair as it requires a bit more attention. If you have a multimeter and are a bit handy, let me know and I will add a few diagrams and schematics for it.
Score 3
Add a comment
Add your answer
Phil Varner will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 83
