The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
496 Questions View all
Which prong does the blue wires connect to on the washer drain pump.
Hi,
Sears substituted the original washer drain pump for my Kenmore compact washer, top loader) model 110.4472. The electrical connections are different.
Holding the new pump with the prongs (male, electrical connectors) facing me, and with the drain pump water inlet on the left hand side, and the water outlet on the right hand side,-- when looking at the prongs, the left prong is vertical and the right is horizontal.
I have 2 blue wires in a connector and 2 black/white wires in a connector and no way of telling which prong to connect to which color.
Any help will, of course, be much, much, much appreciated!!!!!!!!!!!!!!
Thanks, mike
Add a comment
Chosen Solution
If you follow the configurations as I gave them. Holding the pump as I said. The 2 blue wires connected with a female end are connected to the vertical male prong. The 2 black and white wires connected with a female end are connected to the horizontal male prong.
There are only 2 prayers. One is Help me, help me, help me!!!!! The other is, Thank You, Thank You, Thank You !!!
Thank You, Thank You, Thank You, !!!!!!!!!!!!!!!!!!!!!!!!!!!
mike
Add a comment
What do the blue wires on the control board go to Kenmore Top Load using m# W10634026
Add a comment
Add your answer
Michael Gallick will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 19
Past 30 Days: 98
All Time: 6,391
