This is the device page for the Samsung Galaxy J7. The OS that comes stock to the device is Android OS v5.1.
170 Questions View all
J7 Not charging please help
Hello my Samsung J7 does not charge it only indicates that its charging when pluged in but its not filling up instead its reducing what might be the problem so that i can fix it, i love this phone?
Add a comment
1 Answer
@stephen12 could be an issue with your charging IC or your battery. I would suggest you start with a new battery since the next step would be a board level repair. Let us know exactly what model this is Something Like J730F etc. this will be important should you decide you are going to check on board level components.
To identify the location of the IC's post some good images of both sides of your board with your question. Use this guide Adding images to an existing question for that
Add a comment
Add your answer
Stephen will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 5
All Time: 451
