The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
opened dryer while running without hitting pause button
My mom opened the dryer while it was running without hitting the pause/cancel button now dryer wont turn on, the lights are flashing & its keeps beeping. I tried holding down both the start & off buttons but beeping still wont turn off & dryer wont turn on. How do I fix this?
Add a comment
Most Helpful Answer
@hawild unplug the unit from the outlet and let it sit for awhile. Then try again. Keeping it unplugged should reset it. you can also try to hold the "Drain/Spin" button and the "Start (Press & Hold)" button at the same time for no less than 3 seconds
Score 1
2 Comments:
We tried that but it didn't work. Thanks
by
Okay so there is no change when you unplug it?
by
Add a comment
My dryer may be different from yours but i held the cancel button down for about 10 seconds. after that, the start button worked normally
Score 1
Add a comment
Add your answer
Heidi Wild will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 19
All Time: 1,287
