The Mazda Capella was commonly known in markets outside Japan as the Mazda 626. The Mazda 626's sixth-generation was built on the GF platform and released in 1997 for the 1998 model year.
55 Questions View all
Where is 2002 mazda 626 4cyl ECM/PCM located?
Check engine lite came on, code P0400, egr malfunction. Checked vacuum and exhaust flow at egr ports, all ok. Replaced egr valve, did drive test, check engine lite came on, same code. Want to check connections at ecm/pcm, but can't find it. Also, any other suggestions on why the code comes back? I need to get a smog cert. for my license plates. Thanks!
Score -1
Add a comment
1 Answer
Chosen Solution
Looks like something as minor as bad plugs can give you this error. Check on http://www.mazda626.net/topic/30232-626-... for more information about your error code. Good Luck with your inspection.
Score 4
1 Comment:
+ I like research
by
Add a comment
Add your answer
Jay will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 13
All Time: 2,360
