Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Questions View all
I repaired my dock connector on my iPhone 4S but it won't charge
Hello. I recently purchased and replaced a dock connector for my iPhone 4S that had a broken power button and dock connector. However, when plugging the phone in, I get nothing on the screen (when using my wall charger, portable charger or back of PC) and nothing in iTunes - on the PC I do not hear a device connection sound. When using the front USB ports I get a "Device Descriptor request failed" but I do hear the device connect sound. What could be the issue?
Small edit: the phone hadn't been switched on for around two years because the dock connector had broken
Add a comment
Most Helpful Answer
And if this does not help then the replacement charging port is faulty and needs to be replaced with another one. I think the battery is FINE.
Score 2
Add a comment
hey
you need new battery as well and try to put the dock flat with the connector properly
good luck
Score 1
Add a comment
Add your answer
InvoxiPlayGames will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 4
All Time: 55
