Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
How to fix Itunes Error 9?
hello friends, i got an iphone 6 16GB. It shows the Itunes Sign.
When i try to restore i always get itunes error 9. Before it worked great.
I didn't drop it nothing, i just wanted to do an update and this happens.
i tried i4tools but it stays at 20 % "Nor Data".
One time it went to 80 per cent but then crashed.
i spent more than 4 hours on it but didn't find any solution.
Any help would be greatly appreciated.
Score 1
Add a comment
Most Helpful Answer
The iTunes Error 9 is not as common as other errors & usually prompts when trying to update the firmware.
iTunes Error 9 can be a software issue or a hardware issue but I've found it usually to be a case of hardware issues like faulty USB port and damaged cable.
One of the easiest ways that can solve this problem is by changing the USB port. Simply disconnect your cable from your current USB port and plug it in to a different port. You might be surprised of how it can solve your problem during your update.
If your cable is loose, your device loses its connection to iTunes which can lead to multiple errors. iTunes Error 9 can also be one of them. Check your cable if there are any damages or if it is not connected to the port properly. Worth trying another cable just incase.
If you have a different laptop or PC with iTunes installed, you may as well try to use that for updating your phone. This is one of the easiest way to solve the error.
Score 3
Add a comment
hello dear your iphon 6 error 9 is simple problem this is not the big problem. you cannect the iphone 6 your computer itunes then opene your disply and pressing CPU A8 not release your parsing. after flas completed. then releases you pursing.... thanks...
Score 2
2 Comments:
Would you kindly relaborate?
by
Yes it is simple, of couse take shield of the cpu A8 away, connect to itunes and pressing but the difficulty making mechanizm to press if you use your thumb the cpu became hot!!
by
Add a comment
i tried i4tool again and again and again,
it only worked with ios 11 beta.
now my question can i put in dfu mode and restore via itunes normally to ios 10.3.3 or is it better to stay on ios 11 beta?
Add a comment
Hello,
i have the same problem in an iPhone 5s any solutions ?
thank’s.
Add a comment
Hi, i have ifone 6s which was turned off automatically and apple sign comes off on secreen only . When connected to laptop it's give error 9
Add a comment
Add your answer
Transporter Dave will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 12
All Time: 13,700
