Model A1213 / 8, 16, or 32 GB capacity
216 Questions View all
Question Closed
A replacement for the gold antenna?
I had two broken iPod touches that I turned into one fully functioning ipod. The leftover broken one still boots and doesn't have a back light, but I don't want to spend the money to repair it. Instead I want to jailbreak it and turn it into a media or storage server.
The problem is, I broke the little gold antenna in half, and I lost one of the halves. It still detects wifi networks, but will not connect, and I've tried multiple networks.
Is there a replacement that can be found somewhere, or something else that can be used in it's place, such as foil? I've tried a gum wrapper already, but that did not work. The cheaper the solution, the better. Thanks!
*EDIT*
I tried a piece of a foil gum wrapper. My wifi works now. I'm not sure if the wrapper did it, but I know that I don't want to touch it, now that it works.
Add a comment
That is one of those parts that is really hard to come by. To bad that you lost the other piece. I did have one repaired by my local jeweler and they are pretty good in fixing little pieces out of exotic materials. I guess I'd be scouring the usual places like ebay etc. good luck with your quest.
Add a comment
I found a site that sells used ones: http://www.badgizmorepair.com/product/ip...
Hope this helps!
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 2,872
