The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
Why I c'ant see some thing about dock connector?
The Ipad has no charger!
1 Comment
Are you saying that you don’t have a charger for the iPad? Or that the dock connector is damaged? Or that the lightning connector piece got stuck in the connector?
by
Add a comment
1 Answer
Chosen Solution
iPad Air charging issues are very common and may be a headache to fix. A lot of good micro-soldering techs that I know still fail to repair them from time to time.
We now reached a point where we are fixing most if not all of them thanks to the efforts and thorough (and lengthy) research by a fellow "master" tech who shared their results.
In summary, if you are using a known good charger and cable, the problem now lies "inside" and you have to really know what you're doing if you want to successfully fix them.
From experience, some of them turn out to be pretty straightforward and easy, while others are very intricate and complicated to repair.
Score 3
Add a comment
Add your answer
LUIZ will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 74
