This instant camera from Fujifilm now boasts a slimmer and lighter body than previous revisions. The Mini 8 helps the photographer by alerting them the recommended aperture. It also has a High-Key flash mode which helps the photographer attain soft portraits for a stunning look.
355 Questions View all
My pictures are turning out green!?
Hey, so I brought my Instax film mini 8 to San Diego to take pictures BUT when I take the picture the photo comes out with a green tint? I tried changing the film and the batteries also adjusting the lighting, please help!
Score 1
2 Comments:
@rose673 just to make sure, you did not use a monochrome film or settings? green tint on other cameras is usually caused by a failing CMOS sensor.
by
@oldturkey03 Correct, I didn't use monochrome or anything!and I made sure the lighting was correct and everything
by
Add a comment
1 Answer
@rose673 it could be the image (CMOS) sensor. I would suggest that you use this guide Fujifilm Instax Mini 8 Lens Unit Replacement to get to the lens. It appears to be mounted directly to the board, so remove it and check the sensor underneath the lens. Let us know what you find. Better yet, take plenty of images of what you see with your question so we can see what you see. Adding images to an existing question
iFixit Image
Guide
Difficulty:
Very easy
2 - 5 minutes
Fujifilm Instax Mini Eight Lens Unit Image
Guide
Difficulty:
Moderate
5 - 15 minutes
Add a comment
Add your answer
Rose will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 58
All Time: 9,599
