Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
after screen replacment ( verticle lines and withe aea on top )
Hello
Im having a problem with my iPhone screen it shows different color vertical lines and white area on top after putting it back ( before i removed it was working probably ), and its not long screw damage or because of oil , i tried another screen and it works probably .
i appreciate any fast help , thanks in advance :)
Add a comment
1 Answer
Chosen Solution
If your replacement screen has these lines and white area but other screens do not, then it sounds like you have a defective replacement screen.
Contact your supplier for a refund or replacement.
Score 2
2 Comments:
Thanks for helping but i didnt replace the screen , i just had to remove it to fix the camera and right after puttung it back thats happen
and recently both of the screens dont shows anything but the iphone is working
by
Alright, well that changes my approach. It's important to give as much detail and history as possible when asking for remote help :>). I guess it's too late for you to post a picture of the lines so that I can see it.
Did you disconnect the battery before removing the screen? You may have blown the backlight (or LCD driver circuit). Plug in your phone and then shine a bright flashlight on the screen. Do you see a dim image? If yes, the backlight circuit is blown and will require a micro-soldering repair.
If you connect the phone to an iTunes enabled computer, does iTunes recognize your phone?
by
Add a comment
Add your answer
Wajd Gannam will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 77
