Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
342 Questions View all
Replacement HD won't boot
I just replaced a Samsung 500g hd with a WD Caviar 2tb hd in my new iMac 21.5 (iMac 11,2) and when it boots, I get a flashing question mark.
Do I need a Samsung hd instead of an WD?
I thought Wds were compatible.
Add a comment
1 Answer
Most Helpful Answer
You need to boot from your system installation disk. Insert disk and hold down the "C" key while starting up. Go to the second page pull down menu to Utilities, Disk Utility and format the drive. Give it one partition. Now go ahead and install a system.
iMac Intel 21.5" EMC 2389 Hard Drive Replacement
Score 3
2 Comments:
The HD is not recognized at all and I believe it has to do with me using a different brand. I am going to get the right temp. sensor cable and see if that helps.
by
The OWC temperature sensor will not help you to see the drive, it will just stop the run away fan issue if you have changed hard drive brands.
by
Add a comment
Add your answer
erin will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 11
All Time: 786
