Où se trouve/Where is my EEPROM on my bn4102156a mthrboard?
Bonjour,
Apres une MAJ impromptue et non desiree, ma tv samsung UE48h6400WA fais une boucle veille/demarrage et reste allumé 15sec avant de reprendre.
Impossible de faire un reset via les menus, les telecommandes ne semblent pas repondre à autre chose que power.
Je voudrais donc vider la memoire en manipulant le EEPROM, apparemment en le "courtcircuitant" on peut le vider de sa memoire et revenir a la version usine.
Si quelqu'un peut m'aider?
Merci d'avance.
Hi,
After an unwelcome and unauthorized update my "Smart" TV is now looping between on and off and stays around 15secs on between cycles.
I have a 2years and some months old tv UE48h6400AW with a bn4102156a motherboard. It's just past warranty coverage.
My remotes don't seem to have any effects but I can manage to turn the tv off. The joystick in the back is as useless as the remotes.
Samsung told me to unplug it and wait then plug it but it was no use. I opened it up since the warranty is expired.
I couldn't see any damaged condensors but I'm no expert eather...
I just would like to reset eeprom to get my tv back and do a manual update or none at all depending on my confidence afterwards.
So I'm here to find the EEPROM and a potential guide to reset it and get my tv working again. If anyone would help me I'd be grateful.
Sincerely.
Edit:
Voici ou j'en suis.
Here is where I'm at.
Quelqu'un peut il m'aider a avancer?
Merci d'avance.
You can even see my brand new Ifixit kit in the corner of one of the pics xD.
Can anyone identify the EEPROM on there or is there an other that doesn't imply either waiting 2 weeks for a foreign used mainboard, or paying over 120€ for a new French mainboard delivered in 48h, or changing TV which... make sense but is too expansive and not what I'm looking for...
Or does anyone has found the schematics or a repair guide?
Thank you
'''Edit du 23/07/17
TV réparée en changeant la mainboard mais pour tenter une récupération de l'ancienne MB je cherche toujours a savoir comment vider ou changer cet EEPROM et aussi à présent la puce qui gère le son qui n'a apparemment pas supportée le loop de reboots.
Merci.
Hi, I fixed my TV by replacing the MB by a functionning one but I am still interested in finding the EEPROM chip by curiosity and eventually to fix it. I'd also apreciate if someone could tell me where to find the chip responsible for the sound/audio and how to fix it or replace it because it seems it crashed during the neverending loop stage.
Thank you all.'''
Add a comment
Most Helpful Answer
@pepere try to use your original remote to get to the "secret menu". Push Info==>Menu==>Mute==>Power On (TV) in quick sequence to bring up the advanced menu. From there use your remotes arrow keys and enter key to access the different menus. You could start with a factory reset. Let us know what you get.
Score 2
1 Comment:
Hello,thank you for answering, I found the secret combo right away and tried it and failed... I only have 15secs on turn on time and its not enough apparently to even launch this before restart or shutdown. And it seems that only the power button on my remote is doing something. I can't raise volume or change channels, just turn it off/on with the remote. The joystick doesn't seem to respond either.
Thank you though I appreciate you answering.
by
Add a comment
TV réparé par mes soins, j'ai ouvert la bête après l'avoir laissée au repos une nuit, il y a une quinzaine de vis qui retiennent le boitier et ensuite vous êtes dans les entrailles.
On y trouve surtout la mainboard et ses références sur le code barre et sur le circuit.
Je pense que le circuit c'est la carte et son format, le code barre indique ce qui est dessus mais je me trompe peut être. On trouve néanmoins le même numéro de "format" sur différents modèles.
Toujours est il que plutôt que d'aller chez un réparateur agrée comme recommandé par Samsung et surtout plutôt que de prendre ma carte j'ai.... pris ma carte...mais pour acheter via un site tres connu de dont le logo a les couleurs de Google une carte-mère _ Ma télévision aurait été sous garantie, j'aurais assurément suivi le conseil de Samsung. Je trouve même une réplique quasi identique de mon modèle. Celle ci venait apparemment d'un téléviseur du même modèle. Le numéro de modèle était identique celui de série sur la carte correspondait aux deux dernières lettres près qui sont soit des séries de fabrication ou des infos sur le pays d'origine selon moi _ je précise que je ne suis pas technicien, ni professionnel de électronique, informatique ou high tech.
J'ai débranché les 5 câbles je crois qui étaient reliée a la carte en place, l'ai dévissée, ai mis la nouvelle rebranchée, remontée la bête et fait un test sans rien d'autre que le câble d'alim.
J'ai eu un démarrage normal, j'ai de suite éteint et fait une remise a zéro avec info-menu-mute-power et ai fait l'installation. Toujours pas de problème, celui ci me semble bien résolu. Coût réel, 2 heures de trafic, 50 euros de mainboard, de la sueur et du stress contre au moins 250 chez un professionnel.
Merci de m'avoir lu.
Add a comment
Add your answer
Julien VAUTIER will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 1,160
