The screen is black, intermittently
iBook G4 933 MHz-1.33 GHz
Hi! This iBook G4 screen goes black intermittently. Sometimes when I slightly open and close the screen it will get picture temporarily. Seems like a cable is loose or broken. Any idea which one?
Score -1
Add a comment
Chosen Solution
Sounds like the Display Data Cable needs to be replaced. Here's how to do it: iBook G4 14" 933 MHz-1.33 GHz Display Data Cable Replacement
Note there are two different cables, a wide and a narrow, so check to see which one you have before ordering.
Score 4
Add a comment
When the screen is "black", is is solid and black, or do you see a faint image when you shine a flashlight through the Apple symbol from the back? If you see an image, the inverter cable is at fault, since it provides light to the screen and often gets crimped in the hinge. If there's an image, dark screen or not, the video cable is fine.
I'd also pop the back of the screen casing off and verify that the video connector is fully seated. Sometimes the motion of opening and closing the laptop tugs at the video cable and causes it to disconnect slightly (especially when the screen has been replaced in the past, and the video cable hasn't been properly taped down again).
Score 2
1 Comment:
+ the voice of experience
by
Add a comment
Add your answer
Justin Colletti will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,086
