sound but no picture
i have a strange problem with my lg 55lf5700 .the picture went a week ago so i replaced the t-con board but that didnt fix the problem. I replaced the main board and still the problem remained . But i inadvertently noticed that if i unplug the ribbon cable that links the tcon with the main board and reconnect it there is an image for a split second as the cable makes contact.then the image goes.
the backlights are lit however ther is no image except for that split second that i disconnect and reconnect the ribbon cable .
Any insights?
Score
0
That is a strange one. Have you tried flexing the cable in different areas without actually disconnecting it to get a picture to flash? If you can get it to do that it may be worth replacing the cable. You might also try using a pencil eraser to clean the tiny contacts on each end.
I checked to see if there are any firmware updates for your model and did not see any. But you may wish to check as well. www.lg.com.
Good luck and let us know what you find...
by Lewy
yes i did in fact tried on multiple ocassions to flex the cable just to see if there were broken connections inside it that would make/break contact as i flexed it but no that didnt work .the image only flashes on when the either end of the cable makes contact . i am going to clean the contacts but i doubt that will help. but here goes.... i will revert
by Oral Williams
