The Toyota Platz is a supermini automobile that was manufactured in Japan by Toyota from 1999 through to 2005. Designated by Toyota as the XP10 series, the Platz was sold in export markets as either the Toyota Echo or Toyota Yaris.
20 Questions View all
Airco cooling is not working, but the fan stil working and drive
Good day sir,
I have a 2002 Toyota Platz. When starting car running the air conditioning me good, but after a while the cooling falls as a half an hour away. What I have noticed that only the fan runs. What can be the cause of it?
Regards,
Gili
1 Comment
Thank you sir for the information. it was helpful.
by
Add a comment
1 Answer
Chosen Solution
There is a coil in the ac compressor that engages the ac clutch but over time the gap between the clutch and the coil becomes wider which causes it not to engage the ac clutch correctly. Two shims control the length of the gap and they either need to be filed down or one or both need to be removed as the ac coil gets weaker over time. Look in the chilton's manual about checking the ac clutch gap.
Score 2
Add a comment
Add your answer
Shake will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 11
All Time: 133
