Why my phone is doing stuff by itself?
When I'm trying to talk with someone, it ends the call by itself.
Also, when I'm trying to type a number, it starts writing weird stuff constantly, numbers, charachters, letters..
It opens random applications and I'm not even clicking..
I really have no idea what's going on.
Score 2
Add a comment
Most Helpful Answer
Iphone screen is very sensitive temperamental . So go to setting -general - accessibility - tap on 3d touch. Reduce sensitivity.
Score 1
2 Comments:
I don't have that "tap on 3d touch".
I went to accessibility and found stuff and they were all turned off, so it's not about it I guess.
Stuff like talkback, select to speak, swith access, captions, magnification gestures, etc..
by
There is no sensitivity setting then try to reset all stuff on your iphone. Many time when you put iphone in pocket and due to pressure and bending of iphone screen get affected and this automatic stuff starts. otherwise iphone sensor may be the issue . Again check setting
by
Add a comment
hi, its a hardware fault and most likely, you will need to replace your touch screen (it is safer to replace both your touch screen and LCD).
It is caused by microUSB charging port (at least in my case).
Go to developer settings (if you dont have a developer options in your settings menu, activate it by tapping "Kernel version" line in your "about phone" settings. Google for some guides to activate developer mode if you still dont activated it) and in the developer options, thick the "Show touches" option, so you can see when and where is your phone doing these weird touches.
You can bypass these weird touches by moving around and pushing the microUSB conector .. applying different pressures and angles with your finger on it would most likely find you a sweet spot, where these touches dont occur.
Add a comment
My friend started helping me with my phone from her house on her computer getting on my google account and gmail pretty much everything because I am not computer literate or phone literate. Well after that I've been noticing my alarm on my phone is changing all the time like someone's changing it or turning it off so I can't wake up and other things are happening passwords are being changed by itself cannot be done or is the person that's helping me changing it and changing my alarm clocks also?? I need to know
Add a comment
Why my phone keep jumping
Add a comment
Add your answer
Dare Lala will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 11,597
