Why is my samsung level u stopped working and charging?
The headset is not working at the same time not charging ofwhich previously it was.
Hello Kenneth,
My description of the fix can be done by someone with the tools to work on miniature electronic devices
but I think it is beyond the capability of most consumers. If you would like the challenge by all means have a go at it since it is useless as is.
I have a Samsung Level Pro headset that would not charge and therefore would not work with a discharged battery. By looking into the micro usb receptacle where you plug in the charging cable I can see the tiny connection terminal was smashed beyond repair. This would happen if the cable connector was force into the receptacle turned in the wrong position. By opening the plastic encasement the receptacle could be replaced but would require unsoldering it from the circuit board, inserting a replacement, soldering it to the circuit board then cementing the case back together.
the battery of your headset is dead. time to replace it. bring it to your nearest samsung service center
You have to replace the battery of the headset. Take it to a samsung store…and tell the problem…most probably the battery should be replaced.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 21
All Time: 18,708
Does it work while on the charger?
by Aiden
Yes... Its working while charging?
by Ashish Aggarwal
I got the same problem. On mine it does not turn on, unless I connect charger cable and then turn it on... even then, it takes a while to bring bluetooth signal, but eventually it is the only way to work.. but after much shorter amount of time than before, it turns off again.... Is it dead battery?
by alexgrazina
Mine also no power and not charging.. Whare the place can I go to fix or check my headset level u here in the philippines
by tonski8
This hedfone are not turn on
by balakrishnankkbalakrishnankk
