Apple logo then shut off after drop (Not bootlooping by itself)
So here I have an iPhone 5C that is now stuck on apple logo then shut off, which is what you would expect when a battery is not plugged into the phone and you plug the charging cable in.
Seems to look like not detecting battery.
Components C23 and C25 are knocked off. These are both capacitors that are right above the battery connector.
Are both those capacitors required for the iPhone 5C to boot?
These capacitors go to ground and are used for PP_BATT_VCC.
If they are required for phone to boot, then I'll just take the capacitors from an iPhone 5s which are the same.
It won't stay on in recovery mode, it cuts off very quickly even while plugged in recovery mode.
I have tried another battery by the way.
Edit: I have concluded it is probably either NAND chip or Baseband chip. Are they both the same thing?
