The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185 Questions View all
No backlight, black screen, external monitor works ok
I use my laptop mostly with external display via displayport, but laptop always in open state(use internal monitor also).
No water or drop damage -- on half of working day internal monitor became black but external continue working. I try reset/boot macbook with keyboards shortcuts but with no success, so probably hardware problem. I use flashlight to check display and i can see that display working.
In most cases to which part of display(or whole display) this issue could be related from your experience, and from which point i need to start ?
UPDATED: i can see interface if i use flashlight.
Thank you!
Add a comment
1 Answer
Most Helpful Answer
If you can see the desktop icons using a flashlight that tells us your backlight logic on the main logic board is having problems.
You either have a burnt fuse link or the WLED driver. The WLED driver is not something a DIY can do.
It might be best to find someone who does board level repair near you.
Score 1
Add a comment
Add your answer
Эсарт Фардонин will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 202
