Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
How To Replace The Coax Antenna Connection Point
I opened a used iPhone that I want to fix and noticed that the antenna at the bottom right of the phone was not connected to anything and it seems that the connection point that the antenna clips onto on the actual phoneis broken. Is there anything I can do about the phone in order to fix that or if not, what can I do with my broken phone..
3 Comments
@drummerboy0109 post some high resolution images of your logicboard with your question. Use this guide Adding images to an existing question for that. It will allow us to see what you see and hopefully can identify what is missing and what to do about that.
by
I posted a photo of what I need to replace. The tool is pointing to it and mine is broken
by
Add a comment
Most Helpful Answer
If this is the connector you are talking about you could try to re-solder a new one on the motherboard if the pads are still there if the pads are missing its a more difficult task. All this if you have the right tools to do it
(microscope/magnifying glass soldering iron and the skills to do it)
Score 1
1 Comment:
What is that peice called? Can you link me
by
Add a comment
You'd better leave a pic to let us know the details and give you the answer.
1 Comment:
I left a picture in the post. See where it's pointing. Mine is broken
by
Add a comment
Add your answer
Jarred Ford will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 237
