Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Questions View all
Why is there a stain on my screen?
There seems to be a stain streak on my LCD that's apparent on backgrounds that's appeared out of nowhere. I know it's on my LCD because I tried wiping my screen and the stain wouldn't disappear. I don't know how the stain got there, and I'm not sure how to get rid of it. Is this something that requires a replacement LCD or can I just wipe it I have to do something else?
Add a comment
1 Answer
Most Helpful Answer
There are a few possible causes for this. The first is the glass was not fully clean when the LCD display was manufactured, or when LCD & cover glass was assembled into the lid assembly.
  • If it's LCD you'll need to replace it.
  • If you can tell if the stain is on the inside surface of the cover glass you could take the cover glass off to give it a clean
  • If the stain is on the top surface of the LCD you could try cleaning it (use extreme care as you can damage the screen with to much pressure)
  • If you have a very dirty environment you can get ultra fine dust & smoke particles to get caught between the LCD & cover glass sandwich as well.
In these cases its often something you'll see within the first year of use. Frankly, the amount of work to even pull the cover glass off and the left over markings from doing it make this a tough call. If you've never worked on removing the cover glass on a MacBook Pro you might want to just bite the bullet and replace the complete lid assembly. While more expensive it's a lot less work and something a first time DIY can do (see below).
The other possibility is a pressure stain. What happens is something heavy was placed on the lid and pressed the LCD causing the gap between the two glass sheets to be squeezed so the LCD fluid to be pushed away causing the light to not bend as much as the rest of the crystals. Sometimes the glass is fully touching causing a black spot sometimes its just a wipe like this.
The last possibility is the crystals built a bit of memory causing them not to return to the fully relaxed state. This can happen if your background image is very contrasty (burnt image). So you may want to see if you had a graphic that has a shape that has the same outline as your stain, Apple also had a bad run of displays where the LC material the display maker used had containments but its too late to get this fixed by Apple. This also showed up quite soon as well.
You're only hope is replace the display. Here is the IFIXIT guide you'll need to follow: MacBook Pro 13" Unibody Mid 2012 Display Replacement and this is the full lid assembly: MacBook Pro 13" Unibody (Mid 2012) Display Assembly - Apple P/N 661-6594
OK, here's what it will take to get the cover glass off: MacBook Pro 13" Unibody Mid 2009 LCD Replacement pick up from Step15 following the above guide. A common issue many people encounter is they melt the rubber gasket or break the glass in the process. Which is why I don't think you really save here after you add in the costs of the needed heat gun, replacement gasket and the possibility of needing a new cover glass, and if you don't damage the LCD as well (penny wise, pound foolish).
MacBook Pro 13" Unibody (Mid 2012) Display Assembly Image
Product
$164.99
MacBook Pro 13" Unibody Mid 2009 LCD Image
Guide
Difficulty:
Very difficult
1 - 2 hours
MacBook Pro 13" Unibody Mid 2012 Display Image
Guide
Difficulty:
Moderate
30 minutes - 1 hour
Score 2
2 Comments:
Hey, Dan. Thanks for your answer. I accidentally placed my charger on top of my macbook while putting it in my backpack, so it's a pressure stain. I'm wondering as to how I can get rid of it, as well as if you can elaborate more on how.
by
Sorry guy, time for a new display assembly.
Just like how you can't un-crack an egg it's permanent damage.
by
Add a comment
Add your answer
DeadForever will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 900
