2012 Ez-go my battery exploded
Battery exploded. Cause unknown, replaced damaged battery. After charge, it still reads to be on e and won't move. Also my other 3 older batteries are making a kind of bubbling sound. I've taken off the caps checked all water refilled if nessassary. Wiped down the batteries and brushed connections. Don't know what to do. My multimeter is busted so I can't use that. Any ideas???
Score
0
danielsjeff95 sounds like it's over charging. have you checked the regulator? What type of regulator does it have? (EZ-Go uses a few different models)? You checked the wiring? Time to invest in an El Cheapo meter since you will need one.
by oldturkey03
