What is the rear axel called on a 2000 pontiac grand am called?
Hi! I cannot figure out what my rear axel is called. I was in a wreck and I bent my rear axel when they pulled me out of the ditch. When I drive, it pulls to the right so I have to keep my wheel turned to the left somewhat to try and drive straight. But I have no clue how much it will be to replace it, and I have no clue what it is called. Any help is greatly appreciated!!! Thank you!
Score
0
I wonder if you would be lucky enough to fix this problem with a simple wheel alignment?
by S W
All I know is that the metal part of the axle is bent out towards the bumper, but I will see if that will fix it. Thank you!
by Cayci Leann Crabtree
@calecr if theree are things that are bend, a simple alignment will not do. You have a few part on the rear axle so it will be difficult to identify those without actually seeing them. Post a couple of images of the damage with your question. Use this guide Adding images to an existing question for that. It will allow us to see what you see.
by oldturkey03
