Replace Antenna Flex, now wont charge but IS recognised by itunes...
Hey everyone - bit of a weird problem...
MY GPS / Wifi / Bluetooth were all gradually getting worse over a couple of weeks. Airpods would only work within 6 inches of phone. GPS accuracy was off by 200ft.
After some reading here I decided to replace the antenna flex cable and cover, which instantly solved all the problems!
Later that day the phone randomly powered off. I booted it back up. A few hours later it did it again... uh oh...
After a charge the phone is then stuck on 100%. I perform a full restore from itunes - still stuck at 100%. I drain the battery until the phone powers off, then charge. It jumps straight back to 100%.
Today the phone died (still at 100%) and now won't accept a charge or turn on. It displays the red battery symbol when I connect it to power, and it will happily restore from itunes, but then just refuses to boot up - just displaying the red charging icon.
If I disconnect the battery but leave the charger connected the screen still shows the icon, so I know some power is coming from the cable.
It will talk to itunes, so I know the port/cable is at least mostly ok.
The battery is original and has always been fine, so it seems like a stretch to assume that it happened to die at the exact moment I repaired the antenna...
I have taken it apart three times to check all the flex snap connectors - can't see anything wrong.
Anyone got any ideas what this could be? I'm worried now I can't take it to apple and pony up the $300 for a replacement.
