How to repair Sync/Charging port?
I have an iPod Classic (160gb) and have had an issue with the charging port lately. I have it continuously plugged into my Kenwood radio in my car via an official Kenwood cable.
Occasionally the iPod would lose it's connection, and if I jiggled the cord, it would reconnect.
Now, it won't connect in my car at all. I tried 2 other cables with the same result.
I brought the iPod in the house to play with it, and it won't charge or anything via the port. I cleaned the connector with alcohol, and I blew it out with compressed air. No change. What happened?
2 Comments
Upon closer inspection, there are a few bent pins. I tried a toothpick,. It can't get them to sit back down flat.
by VinylAddict
VinylAddict, Straighten the pins out the best you can, use something a little stiffer if need be(non metallic), plug in charger and let sit over night to see if pins will lay flat when removed from charger. No better in morning may have to remove and replace port.
by L Pfaff
