Thin and more powerful than ultra-budget laptops.
20 Questions View all
Noisy fan and overheating problem!
Hi all, my notebook's CPU temp when I run Edge only around 50C, and if I run more apps it starts to get higher and exceeds 60C. In general, fan sounds annoying after 40C 'most time', and it gets worse while the heat is increasing. What could be the possible problem? Does changing the fan solve the issue?
Note:
1) "I cleaned the fan and placed a thermal paste on the CPU".
2) I need the fan to be quiet because I want to record my voice on the PC. At this time I realized that I have a really noisy fan.
Thanks in advance!
Add a comment
1 Answer
Most Helpful Answer
Sounds like you need a good cleaning and thermal paste replacement. Luckily, there's a guide to do so, below. Make sure you take static electricity precautions, and unplug the battery. If you don't have any good thermal paste, iFixit has some.
Acer Aspire V5-571 Cooling System Replacement
[linked product missing or disabled: IF179-010]
Hope this helps!
Score 2
1 Comment:
Thank you, I'm sure I did that we'll. Dose changing the fan help?
by
Add a comment
Add your answer
Hazem will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 12
All Time: 2,296
