Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Questions View all
My iPhone wont turn on after screen replacement
I left my iphone sittimg for a week with no screen put the new screen on and it wont turn on i forgot to unplug the battery but it is recognized by the computer when plugged into it but wont charge or turn on and i lost all the screws to the cables metal plate for the lcd but ice done it before but still
Add a comment
Chosen Solution
Sounds like backlight filter blown when plugging the LCD with the battery still connected to the board.
Could even be just a bad screen even.
If it's recognized by the computer check it on iTunes if it says trust this device or locked with a passcode you know the iPhone has booted up successfully.
Score 3
2 Comments:
Yes it say locked with a passcode so now what?
by
Try reconnecting screen cables while battery is unplugged then plug battery back in and try turning it on again.
If no display try getting a screen tested on there. If it's still no good then the backlight circuit on the logic board needs to be diagnosed by someone that does microsoldering. They can also fix it for you.
by
Add a comment
Is the battery connected correctly? Try checking if the cables are in place since it could easily be a loose cable if nothing comes up on the screen.
Add a comment
Add your answer
Aj Howard will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 453
