Display has vertical THIN green line...
Thanks in advance for any and all help!
A client gave me an A1224 2.4Ghz iMac he was going to toss due to issues...
Replaced OS, started and ran fine, but had multicolored vertical lines on it, super thin ones like maybe 1-3 pixels wide, red, green ones. took a screenshot and the lines were NOT in the screenshot so I deduced from research that the display was the issue. I purchased a guaranteed working one from eBay, and when I installed it, it worked fine for an hour or two, then the mac went to sleep and when it woke up it had a single green line on the NEW display running top to bottom.
Question is, with another line on this display, the same problem is happening, so is there a chance my original display is still good, and my issue is with my logic board and/or GPU?
Forgot to add I picked up a Mini DVI to HDMI adapter and hooked it up to my Pioneer plasma in my living room, and the line was NOT there...
Which should I check next? Id rather buy one or the other, but I dont know which one to buy to try and eliminate the problem. I have not removed the logic board yet to even see if there are perhaps any bad solder joints I could possibly reflow...I just wanted to see if anyone here could put in their .02 worth...
Thank you!
2 Comments
Was this issue resolved?, because I just inherited this same machine with the exact same problem.
by P. Hedron
If yours has the same symptoms on the internal display but the external is clean then you have a bad cable or the connection is bad iMac Intel 20" EMC 2210 & 2133 LCD Flex Cable
by Dan
